- Bear Version: latest
- OS Version: iOS 18 beta
- What were you doing: using the highlighter and selecting green
- What feature did you use: highlighter from the menu
- What happened: it injected a green emoji
- What did you expect to happen: it shouldn’t do this. Green is supposed to be the default highlighter, which in markdown syntax doesn’t require an emoji. This is a flaw versus the default highlighter Green which doesn’t inject the emoji.
