Bear Version : 2.3 (12783)
OS Version : 2.3
What were you doing : syncing notes from macOS → iOS
What feature did you use : highlighter
What happened : markdown was broken
What did you expect to happen : WYSIWYG to look the same in both apps
Steps to Reproduce
Create new note in Bear macOS
Create new list with five items
Highlight all items and type ⌘-Shift-M
For four of the five items, click on each to manually shift them to colors besides the default green
Sync notes from macOS → iOS
Expected Result
Highlighted text looks exactly the same between apps
Actual Result
On iOS, for each of the four items that don’t use the default green in macOS:
They still appear green in iOS
You see their emoji color circles
trix180
September 18, 2024, 8:30am
2
You need to udpate Bear on iOS, please visit this URL on you IPhone
Bear is a beautiful, powerfully simple Markdown app to capture, write, and organize your life.
Take notes, plan your day, journal thoughts, organize tables, create lists and tasks, sketch ideas, link notes together, write a book, and much more....
Confirming this is working after upgrading — thanks!
Side note: it uncovers a separate bug — not with Bear, but the App Store. When I visited my list of apps, it said I was running 2.3; but when I drilled down into the detailed app listing, then it showed an Update button, so the App Store was misleading on the first page.
Okay, I get it.
It’s the desktop application that didn’t integrate the correct format. Both up to date, it’s perfect!
