I’ve recently started to use it for composing text. Just hit on me how cool it would be if one could hide strikethrough text. I can read over it but to really feel the flow of the text I need to delete it and then undo for instance. Which isn’t a nice workflow if you have several noncontinuous pieces that are struckthrough. Just a thought.
I don’t like it. I’m using strikethrough especially to see what avenues of thinking I’ve explored and excluded. I want to be able to see the text, to avoid going down the same route again.
You probably want more something like a comment or revision syntax, like Ulysses does, with a specific Markdown set of characters. That’s a different use case.
