Operation system: macOS Ventura 13.7.3
Web Browser: Safari 18.3
What were you doing: Editing a note
What feature did you use: Using highlighting features
What happened: Highlighting features not consistent with macOS, menu sticky, and shortcut flashes
What did you expect to happen: Highlighting features to work the same as macOS
Feedback: In addition to the typo issue, single-clicking to change the highlight color – like on macOS – doesn’t change the color (double-clicking does, it seems). The pop up menu stays even when you click around away from it. Highlighter shortcut flashes. I know it was stated here that not all shortcuts are available, but didn’t know about this one since it was flashing.
