Testing version: 2.02
What were you doing: Looking at the 2nd column with content that had images in
What feature did you use: N/A
What happened: Images are not showing as thumbnails
What did you expect to happen: To see thumbnails. See example below:
This is the situation after upgrading to Bear 2.
What were you doing: Trying to quit Bear
What feature did you use: CMD + Q or Menu item . Quit
What happened: It did not quit, have to force quit.
What did you expect to happen: The app should quit. Instead, Quit menu item is grayed
