koukol
1
Testing version: Version 2.0 (9803)
What were you doing: Editing a file, trying to toggle a H3 level section
What feature did you use: the shortcut for toggle folding
What happened: header turned into H4
What did you expect to happen: the section should fold
On AZERTY (French) keyboards cmd+4 is the same thing as cmd+’
cmd+shift+’ is equal to screen section capture in os x.
trix180
2
Hi,
I think there’s a string localization issue in the header menu panel, can you please check if you have the same shortcut in Format > Toggle Folding?
Regards.
koukol
3
It’s now cmd+ù, and works fine now, thanks! I don’t know what changed because as of writing it did show cmd+'.
trix180
4
I think the issue is this panel which doesn’t follow the localization
