Hi all!
I know that it is possible to append text via Shortcuts under a specific heading, but is it also possible to get text that is under a specific heading via Shortcuts?
I can do split text actions if I know the heading after the one I am targeting, but I would love to simplify this if possible.
Thanks!
ScottyJ
You can append text to a specific header as follows
Bear’s shortcut actions lack an action for pulling a specific header content but you have access to all the content (note.text
) and you search for the ## header
using other shortcut actions.
This gives me an idea that I could insert a special line of text at the end of the desired header’s content and then use that to be a split point, enabling me to have the isolated contents of a header.
Thanks so much!
