As mentioned in my comment in the Bear 2.9 update thread, it would be very helpful to have the option to browse the tag structure within the Archive. Hiding it, as it works today, can feel unnecessarily rigid and limiting.
In that comment, I use the analogy of a filing cabinet: documents may sit untouched for months or years (archived), but they remain organized. When I return to this real-world archive, I’m grateful to find the documents still organized according to my system rather than in one large pile.
I think many of us would appreciate it if the team could reconsider the strict approach to how the Archive feature works. Excluding archived notes from general search makes complete sense and works well as it is today. I (and likely others) would simply welcome the option to browse the tag structure inside the Archive when needed.
Here is a workaround archive idea. Instead of moving the notes you want into the archive itself, leave the notes where they are, but tag them with \#Archive so the tag itself is not active but can still be searched. You can also put your tags inside code blocks, and Bear ignores the tags, but they can still be searched.
Sorry, could you elaborate on the proposed workflow? I may be missing something.
It sounds like you’re suggesting adding an escaped \#Archive pseudo-tag (either with a backslash or in code formatting) to notes I want to archive. But how does that actually archive them? The notes would still appear in their existing locations.
Using a real #Archive tag would at least let me activate it as a workspace. But it still would not prevent archived notes from appearing under their original tags unless I renamed every tag to make it a child of #Archive. They would also remain in general search results, which is what I’m also trying to avoid (and which the proper Archive feature already does today).
Ok, what if you created a new master note for your archive and listed all your notes that you have in the archive itself onto that master note? Then pin that master note to the top of the archive. My other thought is if you are going back to the archive fairly often to bring up and/or do something with the notes in the archive, wouldn’t that defeat the purpose of having those notes in the archive in the first place? I personally would prefer to search for a tag in the global search and have the notes with that tag show up in the results no matter where the note lives.
I appreciate the suggestion, but that would add substantial maintenance overhead. More importantly, it doesn’t address the issue at the core of my request: being able to use my existing organizational system when browsing the Archive.
I’m not suggesting that I would access archived notes frequently. In fact, in the analogy in my original comment, I was imagining finding a note months or even years later.
That said, I think the frequency is beside the point. It seems to me that how often someone refers to their Archive is an individual preference and shouldn’t be imposed on the user by the app. Archiving also serves another useful purpose: keeping old/legacy notes out of general search results, so they do not clutter results for active notes.
I would prefer the opposite: Archive should remain explicitly isolated from the active library as it is today. I don’t want archived notes mixed into global search results. I only want the option to browse the Archive using the tags I deliberately and intentionally assigned to those notes.
In my opinion these are all far too complicated implementations or workarounds. I still think the option to view the archive as a workspace is the most elegant and intuitive solution.
I tend to agree. Although this would behave a bit differently from the rest of the Workspaces feature, which tends to function more as a way to focus or reduce scope. This, on the other hand, would be a complete context switch. Still, I think it could be a nice solution.
Alternatively, Archive could simply have a clickable > icon to its left, allowing for unfolding the tags directly inline.
Honestly, I could live with either approach and would be happy to leave it to the devs’ discretion what the preferred solution is.
