Paragraph indentation
I would love to be able to indent a paragraph
Currently for one line paragraph I do 4 spaces manually, but that breaks when it goes over to the second line
I do this for hierarchy, without styling clutter
We try to stay close to the CommonMark standard, and if you want a hierarchy, lists are what you should use. It does have a visual bullet, which you might describe as styling clutter, but it is helpful to guide the eyes when you have bigger lists.
Is that page written in CommonMark?
This is actually an example of formatting that would work for me :smiling_face_with_three_hearts:
The indented paragraph here is probably a blockquote, which Bear styles differently.
If only there was a way to use a tab key on iPhone, that would totally work
Or if the arrow keys in the Bear command keyboard also worked on paragraphs (right, left) to create the indentation
You could define a system text replacement that adds this special character. I’m doing it for non-breakable spaces.
