I can’t find a way to paste tables on iOS. I can copy the table from numbers and paste from rich text, html or code but I don’t get a table. I can copy the CSV version of the table but have no way to import it. It’s very frustrating.
Creating tables in bear is painful. Honestly it wold be better if you just decided tables weren’t part of bear, Rayner than implementing them in such a hostile way
it seems that Numbers on iOS has changed the format of the tables that they’re writing on the pasteboard when you copy it, it was working before, but it’s not working now (on macOS it still works, so it’s just a problem with the iOS version of Numbers).
I’ve tried a few other apps and from some web pages and the copy/paste of tables still works as expected, we’ll check what’s changed on Numbers and we’ll fix the paste.
