Pasting multiple paragraphs into a single block quote
When using Bear for research, I appreciate the block quote functionality, but in at least half of all cases, I find myself needing to paste multiple paragraphs into a block quote. However, when multiple paragraphs are pasted into a quote (i.e. after typing “>”), only the first paragraph is included in the quote and all other paragraphs are outside (the bottom example in the screenshot). It would be really great if we could have Bear behave such that all paragraphs will be inside a block quote (top example in the screenshot).
Yep, I can confirm. By the way: at testing that behaviour I either found a bug(glitch or discovered another markdown miracle. When typing > to start a quote, calling the context menu leads to selection of the quotes bar
We want to improve pasting in situations like this. It might be a while before we get to it, but it is on our list.
It’s great to hear that things like this are on your list. As a longtime pro user, I appreciate all the good work you are all doing at Bear!
