- Bear Version: Latest
- OS Version: Tahoe 26.1
- What were you doing: Pasing in from Clause and/or dicating from Whispr Flow
- What feature did you use: Paste
- What happened: I got double bullets
- What did you expect to happen: Pasting one bullet should be one bullet
Thanks for reporting this issue. This bug will be fixed with the next update.
Hello, I grabbed the update and I’m still having the same issue. Is there something I can do to help you identify the problem?
Hello. I’m afraid this bugfix is not present in release 2.6.5 but will be for version 2.6.6.
To resolve the issue of duplicate bullet points when copying from Claude AI, I found it helpful to use the “Paste from HTML” command instead of the standard “Paste” command.
