On iPhone, using the three-finger swipe to quick open a note is randomly opening a different note than the one I selected. I’ve attached a screen-capture video that shows what is happening.
In the video, I attempt to open three notes:
- Sequence 1: I tap on Memory Editing, but a note on Memento Mori is opened.
- Sequence 2: I tap on Memoir, and the Memoir note is correctly opened.
- Sequence 3: I tap again on Memoir, and a note on Mendicant is opened.
- Sequence 4: I tap on Travel Writing, and a note on Team of Rivals is opened.
I have restarted my iPhone, force-quit Bear, etc., but the bug persists. The bug isn’t consistent. Sometimes the correct note opens; other times, it does not. The wrong note only appears when three characters are typed in the quick open search box. I haven’t been able to replicate the error with two characters or four or more.
This only happens on iPhone. Bear on iPad and Mac seems fine.
- Bear Version: 2.6.5
- OS Version: iOS 26.2.1
- What were you doing: Quick Open (three-finger swipe on iPhone)
- What feature did you use: Quicken Open
- What happened: tap note to open, but a different note came up
- What did you expect to happen: Note I selected to come up
