Bear is just about perfect, but because it doesn’t sync with Readwise, I’m stuck still using Obsidian, which I’ve outgrown as too fiddly. Please, PLEASE please work with Readwise so I can export my notes from Reader directly into Bear! As a writer, I have a lot of research notes and my system with Readwise is too ingrained for me to do it manually in Bear. Thank you!
I have the same request.
There are shortcut automations that provide this functionality. I’ve tested one a while ago and it worked. You can find several competing ones on Reddit. It’s more fiddly than native integration for sure, but for the time being, it could help.
I read where others were having issues but I guess I’ll give it a shot. Thank you for the idea!
They can be long to process especially the first time. Give it the time to do its thing!
