This applies to Bear and Lettera. Basically what the title says.
- Set font size in Settings
- Zoom in via View > Zoom In
- Reset zoom via View > Reset Zoom
- Font reverts to default 15pt.
I would expect it to stay at whatever setting I chose for myself and have it treat that as default.
Use case: I set default size for reading, then zoom in while writing full-screen. Reset zoom should then take me back to my chosen default reading font, not factory default.
