I am a big fan of Rose Pine. I have always found it to be beautiful and comfortable, and I don’t have many issues with color delineation.
A couple notes:
The Rose Pine Dawn implementation is great.
The main Rose Pine theme seems to have a few issues. The main one is that it’s using the Iris color for headings. Would you consider looking at alternatives? I think that Iris is typically used for links or smaller elements that you want to stand out, and Iris is so vivid and funky it makes the current theme unusable for me. Here is a generalized example of how the theme should look: GitHub - rose-pine/rose-pine-template: Rosé Pine new repo template
Finally, there is a “Moon” variation of Rose Pine that is soft and lovely. Would you consider adding Rose Pine Moon to complete the set?
