Share Sheet Issue
  • Bear Version: 2.4.5
  • OS Version: 18.6
  • What were you doing: using share sheet
  • What feature did you use: share sheet on iOS
  • What happened: modal pop up appears for a second, but closes down. No option to select note, append etc.
  • What did you expect to happen: share to a note. Unable to do so. Have restarted device multiple times and tried different apps to share something “to” Bear. Same issue.
