From what I can tell there is no way to un-indent bullet points on the iPad app (using Magic Keyboard).
Can you please confirm you are using the latest iOS build? This was fixed with the last update.
I’m using 10817 but even when i go back one build to the one where it was supposed to be fixed, it does not work
Can you please send a quick video of this issue?
The shift + tab does nothing when cursor is at the start of the line. Otherwise it actually tabs the text over.
Thanks! A fix will be available with the next update.
