Operation system:
Windows, macOS
Web Browser:
Edge, Safari, Vivaldi, Orion
There’s a shortcut for searching in the currently selected note list, but often I want to do a global search (in all lists).
Now I have to first open the “Notes“ list and then do the search.
bru
2
Hi, very good point. That shortcut is definitely on the roadmap, it will be become available in one of the next updates.
sebama
3
Isn’t there already, or do I understood the question incorrectly? Go to Edit > Search and you will see it “Cmd + Shift + F” (sorry for the spanish).
Yes, but not in the web app.
bru
5
Hi @marc-io , support for this shortcut just landed as a minor update to the current release. All you need to do is reload Bear Web. Enjoy!
