Sketch background reset to match other sketch background
Hello! I came across this scenario and thought I’d share in case helpful. Not sure if beta OS issue or not.
  • Bear Version: Version: 2.3.5 (12992)
  • OS Version: 18.1 Beta, iPad
  • What were you doing: creating two sketches in a note
  • What feature did you use: sketching
  • What happened: I tried to set the background for one sketch to be different from another, but when tapping into the sketch the background matched the other sketch background
  • What did you expect to happen: I assume that each sketch should be able to have its own individual configuration
Hello, and thanks for reporting this bug.
