Sketch sizing issues
  • Bear Version: 2.3.9 (13079) (Current testflight)
  • OS Version: iPadOS 18.2 (Current Public Release)
  • What were you doing: Changing between notes causes Sketch space size to minimise and won’t return to full size until force quit and re-open.
  • What feature did you use: Moving between notes which include Sketch box’s
  • What happened: Sketch space size minimises to half width and won’t return to full width size until force quit and re-open.
  • What did you expect to happen: Sketch box to be full width when closing sidebar.
Hi,
I rely quite heavily on using my iPad and handwriting using the Sketch feature in Bear. Any time I shift notes and return, the sketch box size is half width, and won’t return to full width until a force quit and reopen.
Is this happening for anybody else?
I have the same problem :frowning_face:
I’m having this problem too! Feels like it wasn’t there until, say, 6 months ago?
Hello, a fix for this issue will be available shortly with version 2.3.10 beta. We are not sure when will be available because the App Store approval process is slow during the holidays.
Amazing, glad a fix was able to be implemented this quickly!
This bug is fixed in version 2.3.10 available now on the App Store.
