Strikethrough bugging around em dashes
If there’s an em dash right before the strikethrough tilde signs, the strikethrough doesn’t work. Deleting the em dash fixes it. documentation:
Markdown is designed with some heuristics to figure out what is a style marker and what is text, and we try to follow that in extensions like strikethrough. So I don’t think it is a bug in this case. If you add a space after the end marker, it will work as expected.
Sounds good. Thanks for letting me know!
