TestFlight v2.4 for MacOS Not Available?
Just installed 2.4 on iOS and iPadOS but there’s no 2.4 yet showing in TestFlight on MacOS. Any idea when it might appear? This appears to be causing some sync issues, as all instances of the app on my devices (I have 4) need to be using the same version.
Thanks in advance — and do love the new features on iOS! :slight_smile:
Hello and sorry for the delay. The macOS TestFlight update is available now
Where do I download that? I downloaded TestFlight for Mac but it does not show up. It is available on iOS but on Mac it says only available for iOS.
Thanks @trix180 — it’s showing up now. Much appreciated!
I can confirm that once the MacOS 2.4 update is installed, syncing is restored.
@trix180 One other question: I’m noticing an option to use the ISO 8601 date format in iOS, but there’s no comparable date option in the MacOS version. Is that intentional? How is ISO date format usage defined in the MacOS version?
I have already set my system date format to use it, but Bear MacOS doesn’t honor.
Your syncing works across all devices? Even for notes without a password? I wonder if you have ADP turned off?
I’m seeing errors in the log related to ADP, specifically:
server message = "Cannot create or modify field 'subtitleADP' in record 'SFNote' in production schema";
Hello folks, there was an issue on the server configuration that’s now resolved, the beta should be able to sync now.
