Text selection color impossible to see
My fav theme Bear has released so far is the Everforest one. However, the background color for selecting text is nearly impossible to see. I’m not sure how no one caught this, but you just plainly can’t see it.
Please raise the opacity or consider changing the color to make it actually visible. Lastly, I’ve noticed this with other themes as well in Bear.
I’m attaching some images to show what I mean. Can even turn it into a game: “Spot the Selected Text”.
It looks like you have something odd going on either on your screen or your Mac.
I took Dieci because it’s the easiest one to work on. The selection color is #4B3B6E and the background is #000000. The result on a calibrated monitor is this one.
Just in case this is somehow a macOS bug, can you try to reboot?
I’ve rebooted my system. This isn’t a new issue I’ve noticed with Bear either. I’ve just never mentioned anything before until it was a big glaring problem with the newest additional themes.
You’ve selected a whole block of text which isn’t a good test because that’s always going to be easier to see as there is a lot more color going on. It doesn’t highlight (no pun intended) the real problem.
The problem really shows when you’re selecting by word and especially by character to fix mistakes. If I’m trying to select up until a certain character, I can’t tell where the selection is. It’s way too faint. Hence why I shared those images. Those images do indeed have selected words and characters, they’re just really faint. You can spot them…you just have to look very hard.
Mine looks like what you shared, so nothing is wrong with my Mac.
The problem: selecting by word or characters…it’s very hard to see.
It’s the most egregious with the newest themes:
The whole paragraph is selected and it’s still hard to see.
With only some characters or a word selected, it’s near impossible.
I can confirm that selections of few words in deici and everforest dark are barely recognizable.
How do you have the new themes? Are you using a beta version?
Using it through TestFlight
We have pushed a beta update and will be available shortly. Let me know if the selection colors improve for those themes.
Thanks, @trix180! I see the changes on the phone and it’s great! On Mac, I updated, but I don’t see a change in the selection color, not anything like on mobile. Must’ve been some mixup maybe?
I see significantly improved selection colours. Are you sure to have installed the latest build 13214?
The changes are definitely significant on the phone. I was excited to see the same thing on Mac, but it wasn’t the case for me.
I even tried uninstalling and reinstalling. Still no cigar :pensive:
That’s how it looks on my Mac:
Ahhh okay. I guess I do have the update then. I wonder why it doesn’t look the same as on the iPhone. It looks so great and really clear on the phone. I guess it is more clear on the Mac now. Thanks for working on that.
For reference…here’s what it looks like on mobile (Everforest Dark):
Yeah, you are not alone on this. I have precisely the same issue. Very frustrating. I LOVE Bear, but this issue really adds a level of friction that makes me close the app and use Drafts instead, which I prefer not to do, but I need to be able to see what text i am selecting.
They’ve made some improvements recently.
What theme are you using? Maybe we missed something when we fixed this.
Okay, folks. This one was totally my fault. Realized I had a increased contrast in accessibility features, forgot about it, and failed to realize that was the cause of the invisible selection highlighting in Bear. Switched contrast back to normal settings, and problem solved. This one was on me.
Love the fast replies on this community forum. Bear is awesome.
