One of the most common things I do is tag content and I usually duplicate a related post and then after entering content I edit the tags.
However, the contrast between selected text and unselected text in tags is almost non-existent, even when I switch to the high-contrast theme.
To illustrate the issue, I have selected some of the text in one of the tags in the attached image. Can you even tell me what text is highlighted?
Bear developers: Can you please change Bear so that text in tags is high contrast when selected? I would suggest white text on dark background for the selected part, but anything high contrast will do.
Thank you in advance for considering this accessibility issue, especially for people who are color blind.
