I should be able to turn this feature off and on per document, or preferably per todo block.
- Depending on the context, in some todo blocks I prefer the completed todo elements move to bottom, in some others I’d like to preserve the display order whether any checkboxes are checked or not.
- If multiple todo items are nested, and the Move Completed to Bottom is enabled, the completed items should only move to bottom in their level, the parent should not move to bottom if any children task is marked as completed. ATM it works that way, IMHO it is a bug.
