- Bear Version:2.5.1 (13605)
- OS Version: MacOS 26.0 Beta (25A5351b)
- What were you doing: export as a Markdown file with base64 encoding image
- What feature did you use: export as Markdown
- What happened: got unexpected newline in base64 encoding string, and the markdown image cannot render when reopen with typora/bear
when open the exported markdown with bear
- What did you expect to happen:
expect the base64 string to be one line string, when remove the newline and ^M, it can be render by bear/typora successfully.
