View-Toggles UX
Can you persist the Toggle Settings between docs and folders or make it an app-wide setting to let the user select their preference?
Also, is ‘Toggle’ the final implementation to hide or view the Styles Bar or Word Count?
How about having it represent the current state meaning if visible then the menu items says hide vs if hidden the menu item says show. Then if set in App Settings the menu items might only persist for the session and not change/override the app setting.
thanks -tom
