Web clipper doesnt capture all images
  • Bear Version: 2.8.1 (14428)
  • OS Version: macOS 26.3 (25D125)
  • What were you doing: Saving a web page using web clipper
  • What feature did you use: Web clipper
  • What happened: Not all images were included
  • What did you expect to happen: All images in the article are included
The issue
I am saving web pages with articles that have images, e.g., this one: Metroid Prime Remastered: Space Pirate Frigate Walkthrough | Nintendo Life
Here is how the web page renders in Safari and I expect that all images are included in the saved web page.
It works for most images, but side-by-side images are not included. See here how images between second and third paragraph is missing.
The workaround
I have found that if I use the shortcuts app and Create Bear Note from URL (not Create note from URL) then it captures also the side-by-side images.
This gets the job done, but it would nicer to be able to use the Safari extension of the web clipper.
