Wikilinks not working on iOS
Latest iOS Version
Adding a wiki link inside of double square brackets
Wiki links on iPhone App
Wikilink is written but a press on it doesn‘t open the link
Opening of the wikilink
I’m seeing this issue too, however, there are two workarounds:
  1. Add a couple newlines below the wikilink
  2. Type some stuff
  3. The wikilink should now be working
Alternatively,
  1. Open a different note
  2. Go back to the note with the new wikilink in it
  3. Tap the wikilink and it will now work
All existing wikilinks seem to work fine.
found that I can press into it by dismissing the keyboard
It’s a problem on iPad when you have a physical keyboard attached, the wikilinks seem not to work.
