A Simple Way to Prevent Tag Chaos in Bear: The Meta Document Approach
I’ve been experimenting with Bear as part of my productivity setup (alongside Things and Apple Calendar), and I stumbled on a method that’s working really well for me. I’m calling it the Meta Document approach.
The problem:
  • Bear’s flexibility with tags is great, but it can also get too organic.
  • Without some structure, tags multiply and the system gets messy.
The solution:
  • I created one “Meta Document” note in Bear that lists all my core tags, grouped by domain (e.g. #journal, #projects/ProjectX, #hr, #compliance/GDPR, etc.).
  • This document is both a map and a governance tool:
    • It seeds Bear with the tags I actually want to use.
    • It gives me a master view of my system.
    • When I add/remove tags, I update this one note — Bear dynamically reshapes itself around the new structure.
Why it works:
  • Journals still capture everything day-to-day.
  • Projects and domains have continuity.
  • Tags stay intentional, not chaotic.
  • Over time, Bear evolves with me, but never drifts into entropy.
It’s lightweight, but it gives Bear just enough scaffolding to stay coherent long-term.
Curious — has anyone else tried something like this? How do you stop Bear from becoming tag soup?
It sounds interesting, can you show the snapshot?
  1. Start small - something like the above.
  2. Don’t use icons / fonts etc.
  3. Build it up as needed. So when you start a new project, just add it to the Works/Projects and you have a pre-built structure.
  4. .Meta tag will give you quick access on the sidebar and the note will be available in every other tag on the sidebar also. So you you be able to adjust and refine very dynamically..
So you created the left hand column index into a note?
