Feature request to add a one-click expand/collapse note in the main window. I know there are keyboard shortcuts for Show Editor Only, but prefer the UX of Evernote where I can one-click expand or collapse a note to full window editing and 'Show notes and editor"
If you just double click on the note when you open it, it will open in its own window.
Yes, that is my workaround. But there’s no easy way to toggle back and forth without opening a ton of windows or not knowing what is a note on its own or the full screen editor of the main window.
Would much prefer a button to toggle. Most UIs have some sort of tray icon to show/hide the side navigation.
You can just swipe to have full screen. Much more convenient than Evernote.
Holy! I didn’t know that… yes, that is convenient. I wonder what else I don’t know ![]()
Maybe the feature request should be on-screen tutorials for features like swipe that are basically invisible.
Thanks!
Not sure if just me, but the swipe to hide/show panels are not working for me anymore.
I noticed a long time ago that this doesn’t work if you disable “Swipe between gestures” in Mac Settings:
that actually worked, thanks!
