After iOS 27 install on iPhone predictive text does not insert word
  • Bear Version: 2.10 (14802)
  • OS Version: iOS 27
  • What were you doing: Typing with predictive text in note
  • What feature did you use: editor
  • What happened: After updating to iOS 27 on iPhone 16 Pro Max, tapping on suggested word in predictive text bar above keyboard does not insert word into note.
  • What did you expect to happen: Expected to tap on word and have it inserted into note.
We are aware of this problem, and we’ll provide a fix as soon as possible.
Based on our tests, the predictive text can’t be selected when the keyboard is showing.
Thank you! I am experiencing this as you’ve described (on an iPhone 17 Pro). Appreciate the response.
Still there (Iphone 17 Pro & iOS 27.0.1)
EDIT: it is working again
