Another Ode for Saved Search
The Friction
Tags in Bear are powerful for both hierarchy (nested tags) and cross-cutting topics. But there’s no way to query across both dimensions without duplicating tags.
Example: I have / for software notes related to my company, and I want a flat SW tag for general software knowledge. Some notes are both — Company-specific and generally useful. Today I have to double-tag them, which creates duplication and cognitive overhead every time I create a note.
What I want
A way to save a search and access it from the sidebar — like a \“Smart Tag\” or \“Saved Search.\”
So I could define \“sw across everything\” as a saved query matching any tag containing sw, or a multi-term search like #company AND #sw. One click, filtered view, no tag duplication needed.
Why it fits Bear
Bear is great because it stays simple. This wouldn’t add complexity to the default experience - just an optional power-user feature for people who’ve outgrown flat tag lists. Apple Notes, Finder, and other native apps have smart folders; it’s a familiar pattern."
This would be so simple and yet so powerful. We’d be able to leverage equations being used to perform granular searches as a way to create smart folders, but without having them competing with tags :exploding_head:
I also agree, this is my most desired feature as it wouldn’t even be “in the way” as if you dont want saved searches then just dont create them. This and native calendar integration for Daily notes are my top two wishes for Bear. Yes ik similar workflows can be re-created with shortcuts but those are buggy post every mac/ios update, dont work on both devices and take more away from the beautiful UI/UX that i get in bear where I would like to have these features.
