Auto save function
I’d like an option to save files automatically instead of having to press Cmd+S.
FYI: Lettera does autosave. If you’re seeing the “edited” word below the title(filename) that just means it’s in Edit Mode and is there for the benefit of folks that primarily navigate with the keyboard. Early on I thought the same thing unless you are literally finding that your files are not being saved.
Just passing it on in case it applies to what you’re experiencing.
-tom
