2.0, iOS
When trying to autocomplete a tag or link to another note, the autocomplete selection fails if the autocomplete pop up menu is covering existing text.
Auto complete tags / links
To be able to select the auto complete option and then it autocompletes my selection.
bolive
2
I see this behavior as well.
Ricky
3
same problem here - makes tagging and creating links a pain
@bolive @tojyouso @Ricky Can you please confirm you still experience this issue? If this is the case can you also provide a quick video?
bolive
5
Good morning. Issue still arises.
Thank you very much. A fix will be available with the next update.
