- Bear Version: 2.2.1
- OS Version: MacOs 14.5
- What were you doing: adding an emoji
- What feature did you use: text editing
- What happened: while adding an emoji, both bear and macos offer autocomplete. sometimes, the macos autocomplete is above the bear autocomplete. if you select the macos autocomplete, then bear crashes.
- What did you expect to happen: bear should not creash
Thanks for the report. I’ve never seen this behavior, if you have the chance could you record a video of this happening?
