Can someone recommend Bear learning resources? I’ve been a Bear user for almost a decade and don’t believe I’m using it to its full potential.
Thanks!
Thanks!
I can recommend FAQs as a starting point for learning Bear’s functionalities
Another good source is our blog
I think a good app doesn’t need learning resources but users’ sharing of their experiences here and blogs are useful.
In the meantime, just explore yourself and feel how it works when using the app, and you will figure out your own ways.
I disagree that an app doesn’t need learning resources. Trial and error (exploring) wastes time.
When you’re new at something, you don’t know what you don’t know. We all need a guide or someone who’s gone before us to show us the way.
Only the simplest of apps don’t need some form of learning resources. I get the sense that Bear is a powerful app that needs more than a Q&A section to learn its capabilities.
