Hi, thank you for your feedback. I can confirm we didn’t push any update for the past several days.
We’re going to try to replicate the issue in order to fix it. To clarify, are you able to sign in? If yes, do you get to see the sidebar or is the whole screen taken by the bear in a spacesuit? Do you remember if anything changed in the way you are accessing Bear? Or did you add any new extension to the browser?
I tried deleting all cookies, and after that, the login screen showed up again. Now I can log in and use my notes just fine.
But the thing is, I have to sign in every time I open Bear Web — it doesn’t stay logged in anymore.
Never mind then, that shortcut on Bear Web on Windows is to change the number of columns shown to 3 (similarly, Alt + 2 changes to 2 columns, and Alt + 1 to a single column when a note is selected).
To avoid having to log in every time you can select the “Trust this device” menu item in the top left menu.
I thought I had the same issue as OP (turns out that I didn’t) as I would only get the bear mascot in the spacesuit on one of my browsers on just one machine. I knew about the ^1, ^2, and ^3 shortcuts keys to change the layout/view, but never would have put that together with this issue I was having – but what you commented here was my issue! Previously, I just resorted to using Bear Web in a different browser for the time being.
