Bear Web Clipper: Saving Entire PDFs From Safari
How do I save the entire PDF to Bear from the Web Clipper extension in Safari on MacOS/iPadOS? On iPadOS, I can use the share sheet option that brings up the little menu box where I can select Link, Webpage, Titled Webpage, and File. Using the Web Clipper, there isn’t an option to save a PDF from Safari. On MacOS, there also isn’t the share sheet option, so there’s no way that I can see that I can save the PDF file itself to Bear.
For instance, how can I send this entire PDF to Bear so that there is a PDF file within a new note: https://dinodata.de/bibliothek/pdf_a/2024/s41598-023-47011-0.pdf
On iOS/iPadOS, you can use the … button in Safari > share, select Bear, and “file” in the top menu.
On macOS, we currently don’t have a share extension, but I can only suggest saving the file and dropping it on Bear in the doc.
