Would that be why I’m finding hidden ** that only show when I select the text? They are invisible and keep showing up whenever I’m cutting and pasting, I’ve no idea where they’re coming from.
Hi, that doesn’t seem related… it sounds more like you pasted (or typed) a text snippet with bold formatting, and when you’re selecting the text in the note, it’s now showing the markdown markers for the bold format (the ** you mentioned), which is the intended behaviour.
Thank you ! Is there any plan to integrate a “summary” or “table of contents” menu into Bear Web soon? I currently have very limited use of it without this feature.
