Operation system:
Windows 11 Version 23H2 (Build 22631.4890)
Web Browser:
| Vivaldi | 7.1.3570.54 (Stable channel) (64-Bit) |
| Überarbeitung | de12898bf4b653e5121862729b799c0b8e52a655 |
| Betriebssystem | Windows 11 Version 23H2 (Build 22631.4890) |
| JavaScript | V8 13.2.152.41 |
| User-Agent | Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/132.0.0.0 Safari/537.36 |
Applying an header style in an unorderded list
Either shortcut CTRL+2 or “Heading 2” command from the style bar
the styles added up, in the unordered list is now an H2-item with a bullet point before
applying an header style should reset certain other markup, e.g. lists
While I was writing this I tested the behaviour on iOS. There it is the same as on the web. Maybe this is intentional. I am not sure if having headings in list is or should be allowed.
Please have a look if this is intended. As it seems other Markdown editors don’t allow this behaviour and they don’t recognise # Heading1 with whitespaces before the #. If it’s not intended the logic for headings should be changed on all platforms.
