Testing version: 2. 05
What were you doing: Upgrade
What happened: Importing notes sign just hangs
What did you expect to happen: Import all notes
can you please tell me more about the number and kind of files you are importing?
Regards.
Hiya,
The issue was with about 8 files, but all sorted now thanks, and the files were only the upgraded ones.
Kind regards
Andrew
