Camera and Photo insertion
Hi!
When I use Bear on my Mac, the bottom ribbon has an icon to insert photos from my photo library. This is great. But there is no option to use my iPhone camera to take a photo and import it directly to the Mac app. I’d suggest adding this feature, as Apple makes it possible across other native apps.
Secondly - on the iOS app, I see an easy option to use the camera to TAKE a picture, but in order to insert an EXISTING picture, I had to Google how to do it, realized that it requires a long-press of the camera icon, and then selecting the Photo gallery icon. This is confusing and unintuitive.
Both the Mac and the iOS apps should have a consistent method - both to add in existing photos from the photo gallery as well as to insert a photo by using the camera. Both should have their own icons and both icons should be available on both Mac and iOS.
To insert directly from iPhone/iPad camera you can right-click on the note’s editor and select Insert From iPhone or iPad at bottom of the menu.
Ah yes - I see it! Thank you
Can this be done from the iPad? In other words, from Bear on the iPad use the iPhone continuity camera to take a pic?
No, unless I’m missing something, the continuity camera functionality is available only on macOS. This functionality is made available by Apple on the devices sharing the same Apple ID, and as far as I can see, Notes from iPad doesn’t have this option.
