Cropping also zooms by itself
Testing version: 11513
What were you doing: Cropping a square image on iOS to only get the left half of it.
What happened: As I was dragging the bottom right corner to the left, the image zoomed in by itself, so now the left corners aren’t matching the edges of the image.
What did you expect to happen: Dragging a corner doesn’t zoom the image in.
Do you mind sharing a quick video of this issue?
I don’t fully understand what’s happening here. When the menu pops up you select crop but nothing happens?
Really sorry, I compressed the wrong file. Just switched the capture in the last message, it should be clearer now. This still happens on my end, with any square image it seems.
