Denied on login after authing
Operation system: windows 11 and iOS 18.3.1
Web Browser:
Firefox and Safari, respectively
Logging in with Apple
Clicked my first time link, logged in with Apple (via system prompt on iOS or via login window with FIDO 2FA on Firefox, then after login accepted by Apple, the below auth issue occurred
What did you expect to happen: login successful
Not sure if this is a known issue, an invite issue, or a bug with accounts with 2FA maybe?
Hi, and thank you for the report.
That authentication error is generated by Apple, so in a manner of speaking it’s out of our control. 2FA is fine in general, on the other hand, Advanced Data Protection affects access to the iCloud API, do you have ADP enabled as well?
I do have ADP on, yes - so based on what you’re saying, it will only work with ADP disabled?
I have ADP enabled, and I am getting the same error…
Hi and welcome to the conversation!
So to clarify, the short version is that, yes, sadly, ADP will prevent access to Bear Web, at least in this phase. We’re actively looking for a solution, and rest assured we’ll keep you posted on any improvement.
Thank you. Here is the error msg in case its helpful:
