Does anyone use zettelkasten in Bear?
Hi everyone, I am curious if anyone use zettelkasten in bear. I take notes extensively on stuff I do, papers and articles I read but coming across zettelkasten and thinking to give it a try. My area of focus mostly is AI so I need to take a lot of notes on research as I need to constantly learn new stuff. Curious if anyone uses bear for zettelkasten and how’s their workflow ?
I use my version of a Zettelkasten. “Points” are notes with my own questions and hypotheses. “Mocs” are structured notes with links to sources and points about specific topics. I also link point notes to each other and to source notes. And I use other tags with keywords.
Hi Atharva,
I do use Zettelkasten in Bear! I set up a system with tags for easy linking between notes, and I try to keep each note focused on one idea. I also use backlinks to connect related research. It’s great for organizing AI research and staying on top of new concepts.
Hope that helps!
Can you explain in more detail your workflow ? Like what type of tags do you use and how do you organize stuff ?
