Drag & drop to assign tags
Operation system: Windows
Web Browser: Chrome
Hi all,
will it be possible to assign a tag to a note by dragging the tag from the sidebar on the left and dropping on the note, or the other way around?
Thanks!
Hi! Thanks for the feedback. Dropping notes into tags is something that is on the roadmap (although so far it’s been low priority), the other way around probably not, as it’s not available in the native apps either.
thanks mate. May I take the chance to ask you a quick thing?
Are you going to implement a feature to see the tags at a glance without having to open a note? Something like the attached screenshot. Thanks!
So far, we don’t have plans regarding tags in the note list, but we are open to taking it into consideration if more people need them.
Alright, thanks for your feedback.
Actually I would like to see tags displayed in the notes list. However I see a big problem. The more tags a note contains (and I usually have many notes with a lot of tags), the more confusing it could appear. At some point it would also become ugly if the tags were displayed in several lines due to their number.
The display should be limited to those tags that are semantically related to the entire note. These are the tags that are placed there when you drag and drop them onto a tag in the sidebar. So at the bottom of the note and hopefully soon also at the top under the title (you announced that you are considering that feature). I think that combination would make for a useful feature.
Yeah this would be a nice feature for sure!
