Feature request: highlight block
The above format is quite common, especially for a tutorial. I do not know its name, so I call it “highlight block”.
Do you think of adding this format in Bear?
I think most of people use bear for knowledge management. I think highlight block can be a quite useful feature in the this scenario.
As we already have inline highlight for words, why not have it for a block of text.
I think it is called ‘call out’.
I personally use code blocks in replacement of that. Would be great to have it as an option though!
Hi there,
Thank you for the suggestion.
As mentioned below by another user, the code blocks we have in Bear acts as a kind of replacement for this.
However, i’ll still pass on the suggestion to the development team to have a think about when we’re moving forward with design elements.
