I frequently include file names in my notes, and many of them are auto-converted into clickable hpyerlinks, which they are not. I encounter this most often with names of python files, e.g. myscript.py, though there are other filename extensions I use that trigger the same behavior (.sh, .nc, etc).
I have read .space link issue, Unable to unlink and at least one other (I’m only allowed two links in this post), so I understand what causes this, that there is no way to disable it, and what the workarounds are.
However, I need to type file names far more often than I want auto-link-detection, so it’s an annoyance to have to use a workaround every time. Any ability for user-configurable behavior here would be much appreciated. Thanks!
MacOS 15.4.1
Bear 2.4.1
